Any non sentra vehicle
By jamaul08
#202413
Ok, so this thread dedicated to my 1986 and 1990 FC3S RX-7s.
1986 FC3S RX-7:
-S4 N/A 13b rotary engine with automatic trans - Jan 2014 - engine and trans both removed
-New fuel pump (&filter) purchased and installed. - May 2013
-Driver side window installed - Jan 2014
The plans:
-Will be kept N/A-auto for daily driving.
-Now that the engine and trans are out, the car will be towed back home for bodywork/paint.
-N/A engine will be rebuilt later this year.
-Auto trans will need a new wiring harness.
1990 FC3S RX-7:
Currently Installed-
-13B Turbo engine - rebuilt Jan 2016
-Wolf v500 ecu (complete standalone) and v500 dash unit
-Magnum 60-1 | 65 T4 .68 A/R Turbo w/ billet wheel upgrade
-Greddy Profec B Spec 2 Boost Controller
-Apexi N1 Dual Exhaust
-Blitz 40mm BOV (x2)
-Tial 44mm wastegate
-"V-mount" cooling setup
-Aeromotive 340lph fuel pump
-1200/1600cc injectors
-Cooling Mist Stage 1 Water/Meth Injection Kit (M1 Methanol)
-Lightweight Flywheel
-Competition Clutch Stage 4
-GTUs rear differential with LSD (4.3 final drive)
-Cusco adjustable coilovers
-Front and Rear sway bars
-Mazdatrix rear camber adjustment link
Coming Soon (some of these are tentative)-
-Energy Suspension Polyurethane Master Bushing Kit
By jamaul08
#202414
The crazy thing is I think the only thing stopping this car from cranking is the aftermarket alarm system that has a built-in starter/ignition lock. The 2nd pic is me trying to disable it ahaha. I almost have it completed removed, but will need to splice some wires back together.
By CVTmodderelite
#202416
interesting. btw, what is ziptied to the A/C lines running across the firewall. looks newer then everything else.
By Jack08specv
#202419
You may have a problem with the coolant leaking into the engine since it was siting for so long with the coolant still in there.
it may have eaten through the gasket or even the block. just a thought.
By CVTmodderelite
#202421
jamaul08 wrote:It's a "rocker". Part of the alarm system. If the car moves.... that thing shakes and triggers the alarm.
Ahh ok, thank you.
By jamaul08
#202422
Jack08specv wrote:You may have a problem with the coolant leaking into the engine since it was siting for so long with the coolant still in there.
Yea, I'm prepping the engine to be pulled, so that we can take a closer look. It is going to be sold as scrap though, as I am purchasing a new one.
By BoostedB16
#202530
My first turbo car was an rx7 :D .... I had an 86 that I did a s5 t2 swap. Had the engine rebuilt with a street port... car was fun on the stock turbo but I eventually trade for a turbo integra :facepalm: . The Integra blew up within 1 week
Miss rotary s though....
By WhiteLightning05
#205078
This gen RX7 was always my favorite :)
Should be a great project :thumbup:
By jamaul08
#205310
Ok, moved the 99 maxima out of the way yesterday. Tow truck will be coming to haul it off to scrap yard in a few days.
Time to pull the RX into the garage and start sanding!
By WhiteLightning05
#208410
jamaul08 wrote:Ok, moved the 99 maxima out of the way yesterday. Tow truck will be coming to haul it off to scrap yard in a few days.
:o :o :o
No more Maxi??? :( :( :(
By 07BlackSpecV
#208419
:o :o :o
Thank God, Maximas are bloated commuter cars.
By nissanguru
#208437
Hell yea bro give me a call anytime you need an extra hand!!
By jamaul08
#213428
Stopped by 3 Face Racing during lunch. The owner is going to see if they've got everything in stock to build me a 13bt. This may turn out to be a cheaper option for me because if I get a used engine it will need to be rebuilt anyway.
He requires a 50% deposit and about a month to build it. He's got my number and will call me when he has gone through the inventory.
The plan is to have the engine built and ready for install at the shop. Once the body is completely stripped and primed for paint I'll have it towed to the shop for drivetrain installation.
By jamaul08
#213429
I'm also shopping around for the 4-piston mazda calipers and 5 lug hubs (they were not an option on the model FC I have). Last time I looked they were going cheap... like 200-300 for full 5-lug swap, including calipers and rotors (vented).
Need to decide on what standalone ECU I want. Looking at BC for coils.
By blkb16specv
#213468
I used to have an FC like this one stripped out as my daily driver!! Didn't even have a passenger seat. I got rid of it because it was a massive ticket magnet, even had a drug dog run through it once... guess the cop didn't understand there were no hiding places.
Also mine idle hunted from 1200-3500 rpm regularly and was straightpiped, kind of a bad combination haha
By jamaul08
#213558
blkb16specv wrote:I used to have an FC like this one stripped out as my daily driver!! Didn't even have a passenger seat. I got rid of it because it was a massive ticket magnet, even had a drug dog run through it once... guess the cop didn't understand there were no hiding places.
Ahhh yes, the infamous straight pipe lol
I'll only be takin her out on the weekends and maybe 1 or 2 nights during the week for fun. I hope the cops stay off my ass, but that's asking for a lot these days :P
By blkb16specv
#213716
I feel like youll be alright, or at least in better shape than i was...
I found a picture from when i sold the car to demonstrate the extend of what a cop magnet it truly was....
  • 1
  • 2
  • 3
  • 4
  • 5
  • 18
